1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Battery charge light
Old 08-11-2015, 09:03 PM
ELT's Avatar
ELT
ELT is offline
I started to notice my battery light comes on during a hard acceleration. So I have been keeping track of it. When the rpm's hit 3200 and above the light comes on bright but never at any other time. I put a volt meter on it and I have 13.4 volts at an idle, as the engine revs up the voltage climes to 13.9 then when it hits the 3200 mark voltage drops right off to 12.4. It seems like a regulator issue to me. The parts store says my 5.4 has an external regulator is that so or is it built right into the alternator?
Old 08-11-2015, 09:09 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
For better help,we need the year and what truck its on.
Old 08-12-2015, 04:51 AM
ELT's Avatar
ELT
ELT is offline
My truck is an 04 F250 with a 5.4 gas engine.
Old 08-12-2015, 06:15 AM
NYCruiser's Avatar
NYCruiser
NYCruiser is offline
Check the belt and idler pulley. Sounds like belt could be slipping at higher rpm.
Old 08-12-2015, 08:57 AM
ELT's Avatar
ELT
ELT is offline
No squeal like a sliping belt. The light comes on bright when it comes on not dim or flikering like a sliping belt or worn brushes, thats why I was thinking regualor.
Old 08-12-2015, 01:58 PM
twall_SD250's Avatar
twall_SD250
twall_SD250 is offline
i have a 01 f250 5.4L and my battery light comes on at times also. sometime it stays on sometime its blinks. it started about a year ago, i took the alternator to have it bench tested 2 different times at 2 different places and both times they told me it was good. i have good voltage at the battery also. i think i have a loose wire or some sort of short in the dash light because i never had a problem starting my truck it never died on me and like i said its been doing it on and off for at least a year. and not every day either. it might do it a couple days in a row and then it wont do it for a week or a month or even a couple months before it does it again. i cant seem to find out why it does it but if you figure out yours let me know please
Old 08-13-2015, 06:15 AM
ELT's Avatar
ELT
ELT is offline
I talked to a tech at the local starter/ alternater repair shop. He thinks I have a short in a stator winding or somewhere in the alternator itself. He said that when a elctronic regulator fails it stops working completly and would not be related to rpm's. That makes sence to me, electronic ignitions either work or don't work there is no in between.
Old 08-13-2015, 08:05 PM
bigredtruckmi
Sounds like a reman is due
joe_r_dog
12-16-2011 12:27 PM
drew1485
03-23-2009 09:38 PM
rhoadc
01-04-2007 07:13 PM
waldreps
1983 - 2012 Ranger & B-Series
10-05-2006 10:22 AM
fiatguy
12-04-2004 06:38 PM
Quick Reply: Battery charge light
