Sponsored by: Real Truck
Battery light still on
Old Jan 4, 2007 | 03:48 PM
rhoadc's Avatar
rhoadc
So a little history. When I would stand on the gas (5.4) and the truck made the 1-2 shift the batt light would blink. Then a while latter the light would come on and stay on any time the rpm were 3 grand or higher. I swapped out the serpentine belt and tensioner thinking they were weak and allowing the belt to slip a bit at higher rpm. Only had time for a real quick jaunt today and the light still blinked at the 1-2 shift. I will drive it some more and see if it comes on above 3000 like it did before. My question is where to gom from here. Does it sound like an alternator? I have had some go out on other vehicles but they didnt act like that (only putting out a charge at low rpm). Has anybody had similiar issues??
Old Jan 4, 2007 | 04:13 PM
redford's Avatar
redford
FTE Leadership Emeritus
OK, there are just a few real basic components to your charging system.
Belt, alternator, battery and cables.
If your battery is OK (do have it tested at Autozone) and your cables are free from corrosion and in good shape, then yes, your alternator is probably in need of a replacement.
Old Jan 4, 2007 | 05:42 PM
rhoadc's Avatar
rhoadc
I was afraid of that.
Old Jan 4, 2007 | 05:46 PM
redford's Avatar
redford
Have it tested. Most parts stores will do that for free. You may just have 1 or 2 blown rectifiers.
Old Jan 4, 2007 | 06:54 PM
ken kenmnedy's Avatar
ken kenmnedy
Lightbulb 03sd,ec,5.4,4x4 red
my alt went xmass weekend got the battery too. 400.00 later all better now (200.00 alt 200.00 yellow top). got a batt light 2 days before bright at idel next day startup no batt light.day three sitting in parking lot running parking lights on radio on started skiping and stalled dead batt. those warning lights mean buiss.autozone check hole system...
Old Jan 4, 2007 | 07:13 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You have a 2006 vehicle? Why wouldn't it be covered under warranty?
