7.3 idi doesn't start
Hi guys.
can't start my 93 7.3 idi.
i wait for the slow plugs then turn the key but nothing.
I have power, batteries are good and charged. Checked the fuse box.. all good.
The started doesn't spin or make any noise. tried to tap it with the hammer before and while a friend was turning the key.
Can a starter die like all at once? Solenoid maybe?
any suggestion is very much appreciated.
One easy test -- jump the solenoid on the passenger fender well, from the small terminal to the battery side large terminal. If it cranks, you've probably got a neutral or clutch switch issue. If not, then I'd try shorting the solenoid on the starter itself. If /that/ works, well, you know where your issue is.
Received 3,110 Likes
on
QA testing on the part of the manufacturer is supposed to solve the "immediate failure" problem, but it doesn't. When troubleshooting, you can never rule out a new part. Just troubleshoot as if you didn't know how old the part was, and go from there.
how do i check the netrual/clutch switch again?
on
on
the reason i ask is because if it is an automatic trans, the shifter may not be completely in park or neutral. if you bump it sometimes it will then start. or if it is a manual and the clutch pedal i wearing, the clutch interrupter switch may not close, and then when you step on the clutch a little more it will close letting the truck start.
on
on
D_A_G_1263
11-29-2016 09:26 PM
6.9 BLUES
03-25-2014 11:08 PM
flatbed444E
13
01-20-2014 06:04 PM
