Help!!! 6.0 nightmare
Old 08-16-2015, 07:14 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
Originally Posted by Firefighter209
Ok just tested the pigtail KOEO with a hand held voltage meter. It reads 5.1. Without the key on it reads .4
Was it plugged into the sensor during the reading
It should be
CHANGE THE ICP it could be bad sensor
  #167
Old 08-16-2015, 07:33 PM
Firefighter209's Avatar
Firefighter209
Firefighter209 is offline
Here is a pic done with the computer scan using Forscan.
  #168
Old 08-16-2015, 07:35 PM
BLADE35's Avatar
BLADE35
Ok then you don't get an easy fix
That's a good ICPV value
  #169
Old 08-16-2015, 07:40 PM
BLADE35's Avatar
BLADE35
If it was me I would go through and using that new scan tool and repost every PID
AT
KOEO
IDLE
2500RPM
SO THREE VALUES FOR EVERY SENSOR
  #170
Old 08-16-2015, 08:21 PM
KES08's Avatar
KES08
KES08 is offline
Have you checked the harnesses where they plug into the ECM/PCM? Only reason I ask this is bc my buddy has a similar issue and found his harnesses plugs were corroded and making a bad connection to the ECM/PCM. Might be worth checking at least.
  #171
Old 08-16-2015, 09:08 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Originally Posted by evan1242
dang that sucks!
are they not letting him in at all, or just not yet?
So long as I don't have the tools not problem. They will even
let me bring the laptop.
Originally Posted by lupuseven
If he can, show customs this thread!
it shows his full intent.
They told me that even doing it for free infringers on there workers.
On the Southern border comment. This was Canada's boarder and not
the guys from US border. Hell even the US guys gave me some grief.
I do have one up side. My passport is about 5 years old and no stamps
till today. The US guys gave me an entry stamp.
Cheezit, correct me if I get this wrong.
On other points I talked to Cheezit for about 20 minutes.One thing
that came up is he said that sometimes in cases of stiction spool
valve may get stuck at the end of travel when hot and then dump the
high pressure oil.I also brought up what if a broker leg on one of the
snubbers in the stand pipe gets lodged in a spool valve in just the
right way to allow oil past and as the oil warms up more goes past till
you get a hot no start.
Here is the data sheet on that problem.
http://alliantpower.com/sites/allian...03-08r1_en.pdf
stiction and other stuff
http://alliantpower.com/sites/allian...01-09r1_en.pdf
http://alliantpower.com/sites/allian...02-08r1_en.pdf
http://alliantpower.com/sites/allian...01-08r1_en.pdf
At 4,000 PSI it does not take much of a nick on the O-ring to get a lot of fluid loss.
Here is a good training manual.
http://gershon.ucoz.com/FORD/51s08t1.pdf
Sean
6.0L Tech Folder
  #172
Old 08-17-2015, 06:08 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Here it is
Corrected photo. This is the orientation that you
will be seeing on that side.
Sean
6.0L Tech Folder
  #173
Old 08-17-2015, 07:09 PM
IHateCommieCars's Avatar
IHateCommieCars
IHateCommieCars is offline
I can see how having tools is an unfair advantage over the Canadian techs. Hell, a pair of shoes will get you a lot of jobs in Arkansas.
  #174
Old 08-17-2015, 07:17 PM
IHateCommieCars
Boys, it's one thing to use anonymous user names to post "expertise" online. But, for Sean to put his have-tools-will-travel butt on the line, in front of this crowd, to help a brother in need - that's some strong stuff. Send me your PayPal, Firefighter, and I'll buy the beer.
  #175
Old 08-17-2015, 07:50 PM
Firefighter209
Lol get Sean to send you his! He is the one who deserves the beer!
  #176
Old 08-17-2015, 08:31 PM
Firefighter209
Ok so Sean knows, but the rest of you do not. Took the truck for a long drive on the highway. Brought it home and did an air test through the ICP. Heard nothing. Left it on for 5 min all of a sudden it starts pissing air like crazy! Got it down to fuel rain on passenger side but can not seem to find the exact spot.
  #177
Old 08-17-2015, 08:46 PM
04badford's Avatar
04badford
04badford is offline
Fuel rail nipple cups,OOpS can I say that or will I get bustee by the Mountee, kidding good Effort Sean, hope it didn't put ya out to bad Broutha
  #178
IHateCommieCars
But you should be handing them to him.
  #179
Old 08-17-2015, 08:47 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
Nipple cups were done when O ring for injectors were done.
My money is on the NC Orings. We didn't have good luck changing them out on my brothers truck. Do you remember what brand you used? You might have to get a good light and a mirror.
  #180
Old 08-17-2015, 09:23 PM
Firefighter209
We used Alliant power.
Quick Reply: Help!!! 6.0 nightmare
