Rob's rig - new IP and R&D Nozzles
#46
Update!
I just pulled my injectors; it's been 1k+ miles and I thought I'd check on them.
Also, I was getting a bit of a lope/vibration. I figured one of the shims had a burr which had gotten mashed down over time, and the pop pressure was off.
I pulled all 8 injectors, and found:
6 popped at 1800 PSI +-
1 popped at 1750 PSI +- (Within tolerance - just a little lower)
1 poured all the oil out the side hole.
That last injector was my issue. Turns out the bottom section had come loose - injector builder(me) error. Tightened it up, and it tested at 1850 PSI. I took my shims and sanded them on a flat grind stone, and got it to 1800 PSI.
Put them back in, and it's sounding better. I also noticed that it's more retarded than I thought it was; Perhaps that injector had been firing early(when it fired at all)?
Overall, these injectors are all working, though I did notice spray pattern variation between them -- I had one that liked to spray off to the side in two streams about 10deg from straight, and another that sprayed in a nice straight line straight down. The others were between them in pattern.
Does it matter? I don't know. I'm just glad I have an IDI instead of a direct injected engine, where it /would/ matter.
Good info.
Did you clean the nozzles at all before reassembly?
The biggest worry I have had in terms of the stage 1's is long term "coking" of the orifice, simply because I do the modifications in house, and the pintle is still the same unit as the stock nozzle, so it doesn't automatically "de-coke" itself like the smaller orifice does, or at least that would be a worst case.
It may end up that I have to have the supplier do the modifications for the stage 1's prior to me getting my hands on them, which isn't necessarily a bad thing, now that I have a good relationship with them, and they know I have a real operation, they are more likely to invest the time in more than one style of nozzle. We'll see.
Have you run the truck yet?
#47
Nope. 7 of them I didn't even take apart, I just tested.
The 8th, I never pulled the pintle/nozzle apart.
This could explain the varying spray patterns;
As far as longevity/issues... We shall see. I'll keep an eye on things.
Yup; I ran it about 100 miles on Saturday, then another 50 today. I advanced it a bit more than I had yesterday, and it seems slightly better...
It's smoking a blue/gray haze at WOT above 3000 RPM, though(Floored in third accelerating up a hill)... I think this may be because it's currently too retarded up that high. I'll advance it a bit more and see how that works.
#48
Rob thanks so much for the tip about the trim screw!!!
I have timing gear but this pump is tilted so far that it's a real pain to move it a little here or there. After I got new injectors it needed a ton(relatively) of advance.
This helped dial in my timing SO much easier. I can do it on the side of the highway in 3 mins.
Well done sir!
Well done sir!
#49
Well done sir!
Well done sir!
Depending on how it feels, you might try playing with the light load advance cam as well - I try to get the trim screw to where it feels right under heavy load/WOT, and then adjust the light load advance cam for most responsiveness/feel/power/clatter at low-part throttle. If you rotate it counterclockwise, you will have more advance down low; rotating it clockwise will retard it sooner.
BTW, exciting news! I've gotten a second set of Stage 1 injector nozzles from Justin; these being slightly refined versions of my other ones. When I get a chance, I'll put them in and see how they do.
The previous ones still work just fine, but better is better!
I'm also planning on purchasing a new turbo from Justin. We went over the specifics, I got to take a ride in the Bronco(Frigging /awesome/), and it looks like I want a Stage 1 with a 1.0 exhaust housing. Now that I know what I need, I just need to come up with the $1,250 to pay for it. I just about bought it yesterday(and put it on a credit card) when I was with Justin, but the less impulsive part of me prevailed.
Ah well, should only be a couple of months. Now I have a goal!
Also, Justin determined that the chuffing noise is probably exhaust manifold gaskets, so I'm going to need new(better) gaskets soon.
#50
Yeah I've been goofing around with the light load cam and found some benefit but mostly I'm trying to get my WOT dialed in.
Once I put in the new injectors my top end disappeared. After 2500 rpm there is a serious loss of power compared to my super-old injectors.
My only theory is that this bad Pensacola "rebuilt" pump can't handle the volume at whatever PSI the new injectors pop at.
The trouble is I only have like 40k on it...
If the trim screw affects the advance curve I can't tell-- the changes I've made affect the entire power band uniformly AFAIK.
Nice updates! Let us now how the new ones run!
#51
You might well have one or two failing injectors, firing way too soon. And unless those new injectors came from R&D, they may well be cheap rebuilt crap.
You can also then drop the injector pop pressures uniformly(say, try 1400 if needed), to get your high end back until you get a good pump.
#52
So...
I figure I ought to post more pictures!
3 weeks ago, I, hauled 6 tons of hay(trailer is 3600lbs+):
I learned then that having the emergency brake on makes a trailer harder to pull... But 248 HP makes it possible.
I also learned that this sort of stress is not good for weak exhaust flanges:
But Justin came through!:
This also happened to be on my birthday, so it ended up being a good birthday present... Even though I totally forgot about my birthday at the time due to worrying about my poor truck!
This got it back on the road and sounding better than ever.
So, Friday I hauled our tractor back to my parents.
Not wanting to waste half a trailer load, I decided to balance the load with a bunch of pallets, too!
Truck performed well... Once it got warmed up, I maintained 55 most of the way. Dropped some speed going up hills, though...
Sunday, I hauled a nice light load, only 3 tons of hay:
Unfortunately, this load should really have been balanced better... I'm guessing I had somewhere around 3K on the tongue.
It kinda pushed my rear down... Still hauled OK, but it wanted to drift a bit. Probably because of all the weight taken off the front tires...
edit:
Note - despite the rear being pushed so far down, the tires were /not/ bulged out excessively. I love these XPS Traction tires.
And it still runs good!
I still want to put my new injector nozzles in it just to see, but the lack of an exhaust leak makes it sound and feel smoother.
edit:
#54
#56
Listen, if I was good with Electronics (I feel good about building my own MS2x2.2 unit for my mustang 7 years ago), I would totally figure out a way to control the metering valve with a stepper motor.... It would take all the fueling downfall's out of the question, bottom line.... Rob, please man, beat me to it...
#57
And then we add the inherent unreliability of computer-controlled bits on top of all that.
Sure, it might be fun to play with, but... I still want a P-pump!
#58
It might take the fueling out of the question, but we still have the issues with timing curves and advance and all this other crap.
#59
That's what I thought you meant. I know the Ds4 pumps have inherent issues but I was looking at adapting that eventually. The easiest way to use it would be to use the stock computer and sensors. The problem is making it spin the correct direction. I'm thinking the optical disk wouldn't function correctly if it was spinning the opposite direction on a Ford. My thinking is that since the timing slot for cylinder one is bigger, that it wouldn't work. So consequently I believe I have to make it turn the direction a Chevy does. The only thing I have come up with thus far is using an idler gear between the cam gear and ip gear and then have new injector lines made to the correct cylinder 360* opposite of our stock pumps. If you guys have any better ideas let me know. Additionally, I have looked at Megasquirt. I think it could work but I might need some of my co-workers to help me with that. Additionally, I do plan on correcting the issue with the PMD so that it doesn't fail like it does. Sorry for the derail.
The only hard parts are getting an O-ring in there somewhere to prevent leakage around your shaft(like the throttle lever has), and some computer bits to drive it. An arduino would be fine; just need some basic inputs(variable resistor for the throttle position, variable reluctance sensor converter and frequency-to-voltage converter for a basic read on the tachometer; all done well under $50 in parts.
Just... quite a bit of work. And then lots of tuning.
Brad Leroy
08-25-2017 03:17 AM
MandRServices1
08-27-2009 10:19 PM
