NEED EDUCATION ON ATF
Old 07-13-2015, 08:44 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
I will be having my new Redhead steering box installed soon and have decided to replace the high pressure hoses and go with synthetic fluid. I was told today at my NAPA store that all ATF / Mercon V is synthetic. Why then does Valvoline ( who manufactures all of NAPA oil and fluids) label some as full synthetic and others with no such designation? Also the "full synthetic" that they carry is labeled Mercon LV? Is this backward compatible with the regular Mercon V or made specially for the newer vehicles listed on the bottle?
Thanks, Mike
Old 07-13-2015, 09:25 PM
Thomas White's Avatar
Thomas White
Thomas White is offline
MERCON V's debut was 2008. It replaced MERCON, MERCON-ATF, DEXRON III, and TYPE-F. There is nothing Backwards Compatible with MERCON V. At least not yet. However, MERCON V is Backwards compatible with MERCON, MERCON-ATF, DEXRON III, and TYPE-F
Check this out: - Bob is the Oil Guy - Bob is the Oil Guy
The classifications of oils is: Semi-Synthetic and Full Synthetic
Prior to MERCON V there were Power Steering Fluids and Transmission Fluids which were not compatible, i.e.: MERCON-ATF, DEXRON III, and TYPE-F
As I understand it, MERCON V brings it all together into one lubricant for both Transmission and Power Steering. It was discontinued in Transfer Cases in 2012 and replaced with XL-12 designed for one specific use.
Tom
Old 07-14-2015, 07:08 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Synthetic in laymen terms is merely man made, lab based. Dino oil is from the earth. MerconV is just that. I would not use any other fluid in place.
Cheapest I found was Walmart Supertech at $4.27 a qt back in May.
Old 07-14-2015, 09:00 AM
hydro man 17
Thanks for the replies. Did some research and the Mercon LV can not be used where MerconV is called for.
Old 07-14-2015, 12:41 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
The LV is used in the 5R110 trans with the 6.0 crowd.
Old 07-14-2015, 04:11 PM
Thomas White
Here are the Fluid Application Charts
Old 07-15-2015, 01:51 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
That is a nice chart for gassers, our trucks are not listed. You got one that covers our trucks?
Old 07-15-2015, 03:20 PM
rufushusky's Avatar
rufushusky
rufushusky is offline
This isn't a bad one either...
Old 07-15-2015, 05:06 PM
Thomas White
That was the one I was looking for!
Some day soon I am going to have to go through my remote access server. I've got just under a TB (probably 500GB on Ford Alone). I've let it morph into a trash repository. Time to start adding folders and indexing files.
Tom
bbsitum
1997 - 2003 F150
44
01-23-2024 09:14 PM
kawika
49
06-23-2021 11:47 PM
gabocar
Oil & Lubrication
13
08-25-2008 04:18 PM
schmity
01-13-2007 12:29 PM
John with beastly 302
Oil & Lubrication
03-17-2003 10:00 PM
Quick Reply: NEED EDUCATION ON ATF
