I am trying to remove my starter and am having no luck. I guess I need to know how many bolts there are and where they are. If there are any instructions out there that would be great.
Check this link out. Helped me a lot the first time I did a starter on these trucks. Get a couple size extensions to see what works. Personally I got along fine without a universal socket..if you remove the tire and have someone guide the socket onto the top bolt that saves a LOT of frustration I've found. http://www.happywrenching.com/ford/f150/ford-f-150-starter-replacement-removal-and-installation.html
