Does your truck do this??
Hi, I have a 2012 f150 stx. I have posted in the past and didn't get a response. So here it goes:
Part one:
I want everyone to start their f150 and after it idles down(warms up). Watch your tachometer needle closely. Does it bob up and down slightly? Some may call it surging? Please let me know I would like to know if it is an issue or not.
Part 2: when my truck is shifting into 3rd gear it sounds bogged down a little so I paid close attention to the RPMs and after it has clearly shifted into third gear and I am still accelerating the RPMs lower then increase as if it's shifting again but it's not then once the RPMs reach that point it shifts into 4th And the RPMs shouldn't be lowering if i am still accelerating.
I can video it from an iPhone I just can't figure out how to get it on here. Thanks!!
Part one:
the shifting and slight bog shortly after shifting into 3rd is the torque converter locking up.
mine will even do it if you put the shifter in "3" and mat the skinny pedal. after the truck gets up some speed the truck will lock the converter even at full throttle.
it does feel like a slight bog when it does it though. locks too early in my opinion. but the, the only ford truck i've driven that i thought shifted right was my 99 f150 4.6 4x2 at work (last work truck).
https://www.ford-trucks.com/forums/1...l#post14068979
watch the RPM's at 5,000 in 2nd gear in this video. it is locking the converter at full throttle in 2nd gear. it's just what they do, on only in 3rd in yours and mine (2010 work truck)
...when my truck is shifting into 3rd gear it sounds bogged down a little so I paid close attention to the RPMs and after it has clearly shifted into third gear and I am still accelerating the RPMs lower then increase as if it's shifting again but it's not then once the RPMs reach that point it shifts into 4th And the RPMs shouldn't be lowering if i am still accelerating...
I'd recommend getting your truck into the hands of your dealer; they'll take a look and determine if it's behaving normally or not. How many miles are on your rig currently?
Crystal
Crystal
