I have noticed a slight shudder almost a shift in 3rd gear, is that the converter lock up or do I have a problem?
as i go up through the gears it goes fine into 1st 2nd and 3rd but then it is almost like it shifts again in 3rd the RPM's drop and then work their way back up to 4th and everything works fine
should I be concerned?
thanks
