Stubborn rust
Received 4,132 Likes
on
Stubborn rust
I have a hood that appears didn't have paint on it for some time in the elements, I've tried using a 3M bristle disc and even resorted to a 40 grit flap disk, this is the toughest rust I've come across, it leaves what looks like mill scale for plate steel only harder to remove, I'm leery of sandblasting it in fear of warping the flat section of the hood (53-56). I was also considering electrolysis but need to find myself a kiddy's swimming pool large enough for the task. Anyone else come across rust like this and if so how did you tackle it?
on
I would treat it with Rust Mort and follow the instructions before and after treatment, then prep/prime/paint.
SEM Rust-Mort
SEM Rust-Mort
on
SEM Rust-Mort
SEM Rust-Mort
Forgot you were in Canada. The link was more for example than to order from, anyway. It's a SEM product, and I'm sure they sell in Canada. Your local autobody supply store should have it. That's where I always got it from. Unlike POR15, this isn't a thick coating, it's thin like water and works better than POR, imho. It's intended to be coated, not be the coating like POR.
on
on
