Traction control dry/paved/summer roads
Old 06-29-2015, 11:22 AM
nlfireblade's Avatar
nlfireblade
nlfireblade is offline
My traction control has kicked in a few times lately, when taking a left turn. I hear the noise associated with TC working and the light on the dash flashes. I'm not turning too quickly, it has nothing to do with how I'm driving.
Has anyone else had this issue? Ideas?
Thanks!
Old 06-29-2015, 01:41 PM
Olytlr's Avatar
Olytlr
Olytlr is offline
Are you stock or lifted? It sounds like a recalibration of the VSC and/or ABS system may be required.
Old 06-29-2015, 02:03 PM
nlfireblade
I have a 2.5 front/1.5 rear levelling kit and 33.6" 305 BFG's
Old 06-29-2015, 08:01 PM
meborder's Avatar
meborder
meborder is offline
2009-2010's seem to be more sensitive to lifts and bigger tires screwing up the RSC.
i've never had the RSC or TC kick in around corners in my 2010 unless i'm doing something REALLY stupid, but i'm all stock.
bad wheel sensors would play havoc, so that's something you might be able to check ... just a couple thoughts.
Old 06-30-2015, 10:39 AM
FordServiceCA's Avatar
FordServiceCA
FordServiceCA is offline
Official Ford Rep
Hey nlfireblade,
Have you had a chance to speak with your Ford Dealer about this? Shoot me a PM with your name, VIN, current odometer reading, dealer, and best daytime phone number - I'll gladly look further into this and see how I can help.
Nick
Old 06-30-2015, 03:58 PM
shortride's Avatar
shortride
shortride is offline
I would suspect that you may have driven on some sort of a slick spot on the road. If the TC detects the slightest amount of slippage between a tire and the road surface this can happen.
Old 07-01-2015, 10:05 AM
'78F250351m's Avatar
'78F250351m
'78F250351m is offline
Thanks!
I've had the same thing happen a few times. When I make a sharp left turn it sounds like TC or ABS is kicking in. Maybe my 2in leveling kit is affecting it?
Old 07-07-2015, 12:14 PM
nlfireblade
It hasn't happened recently. Funny thing is that it was happening on the same two turns. They aren't slick at all. Close to home so I'm wondering if it has something to with the truck being just started. If it starts up again, I will call the dealer and bring it in.
Old 07-07-2015, 01:03 PM
96grimreaper's Avatar
96grimreaper
96grimreaper is offline
My 2010 when it was leveled on 34's would kick on the traction control occasionally during turns. Once I lifted it on 35's it rarely did it, only if I was going a little too quick. My leveled 12 and 14 never had the issue.
Stormhammer
2009 - 2014 F150
05-19-2017 07:16 AM
5 Star Tuning
2015 - 2020 F150
11-29-2016 04:45 PM
fordman19762003
1999 to 2016 Super Duty
31
01-06-2016 08:19 PM
cummins cowboy
6.7L Power Stroke Diesel
59
12-28-2012 09:50 PM
JCHH
6.4L Power Stroke Diesel
03-24-2010 10:52 PM
Quick Reply: Traction control dry/paved/summer roads
