today I was tearing around a little bit on the my snow covered yard and when I made a turn and gunned it to get the back end to kick out the traction control light would flash once and the truck would straighten out. Is this normal for the light to come on in this type of situation? I'm usually pretty conservative when I drive and don't spin the tires but today I felt like tearing around.
As mentioned, pressing and holding the traction control button will turn off or limit the various traction functions. Pretty sure one of the functions goes into a less aggressive mode, rather than being completely disabled. I understood it when I read up on disabling traction control several years ago, but have since forgotten. I generally disable traction control when plowing (and lock the rear).
OT.... My wife's prius will actually stop the vehicle from moving (from a standstill) when snow or ice conditions are right. That stupid car was dead in the water at the top of our driveway last winter, with no traction control disable button. Later discovered the prius can be put in a special "maintenance mode" to disable traction control after a long and complicated series of key turns, brake presses, etc...
Some of what you're describing is stability control operating in conjunction with traction control. Traction control acts to regain traction by cutting engine power and braking the spinning wheel. Stability control senses a skid and acts to regain control. It does this most commonly by braking the outside wheels in the skid to bring the truck back in line.
You need to disable all of this to do a donut. Tried forcing a skid with the parking brake last weekend and the system stopped the spin by braking one of my front wheels. Pretty impressive what it can do, but it's not much fun!
I hate these systems. I've been stuck or almost wrecked from the truck doing something while I wanted it to do something else. Even if I disable the crap by holding the button I still can't slide the truck. Anymore when I need it to act like a real truck I start pulling fuses.
I know this thread is about "fun"doing doughnuts and stuff. I also figured out how by disabling the advance trac and traction control. But there is a black box in your new truck. If you disable all that stuff your insurance may discover that and it could be a problem if you get in an accident. I just leave it on unless I'm off road... Believe me I don't like having a black box!
Jim
Geez I'm sorry I meant was if you get in an accident and you had shut off all those traction aids you could have a problem ... I do enjoy spinning those tires too!
Jim
Jim
Currently that recorded information is only available to the NTSB anonymously so they can compile statistical reports (how many people were wearing their seatbelts before an accident, did the airbag deploy, etc.).
However, if the information in a particular vehicle were to be subpoenaed, they would certainly turn it over. At this point, it would take a very compelling reason to obtain a subpoena, but the definition of compelling is becoming less "compelling" all the time...
