Thought it was shaking, but the frame is bending…with video
Old 07-12-2015, 12:18 AM
nateairman's Avatar
nateairman
nateairman is offline
Diesel Brad
Where did you use frame steel? It looks like you just used part of another frame. How did you remove the flanges without over heating it?
Thanks for the idea as I need to fix the frame on my truck!
  #32
Old 07-12-2015, 07:20 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by nateairman
Diesel Brad
Yes, I used another frame, just like I said.
I cut the flanges off just like I said
  #33
Old 07-12-2015, 09:18 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
Brad, wires and lines routed inside the frame seem simple to pull away so the frame plate can be slid behind them. The spring and shackle mounts need to be unrivited and frame mounted side steps removed. What else needs to be done to be able to do this in the driveway?
  #34
Old 07-12-2015, 05:45 PM
nateairman's Avatar
nateairman
Got it. Did you zip disc, plasma cut, torch??
I am looking a t a frame tomorrow and want to grab it as I will be doing leaf springs, brake lines, and a rear tank
  #35
Old 07-13-2015, 04:19 AM
Diesel_Brad
The inner crossmember braces had to be removed as well.
I used a jig saw to cut the frame
  #36
Old 07-14-2015, 07:33 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
Did you have any problems with misalignment caused by the frame being 1/2" wider (two times the 1/4" frame/plate thickness) at the crossmember braces?
  #37
Old 07-16-2015, 08:02 PM
Diesel_Brad
I clearanced the plate where the braces were
  #38
Old 07-18-2015, 09:59 PM
ceetwarrior's Avatar
ceetwarrior
ceetwarrior is offline
That's pretty sweet Dieselbrad, bad *** actually. I have a CCLB now that I used for parts to build up my CCSB. Would love to do this with the other frame!
  #39
Old 07-19-2015, 08:04 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
Looking for a frame crossmember if anyone is cutting their frame up. Ideally it would be for the rear cab as it has brackets that support the bottom part of the frame too.
  #40
Old 07-20-2015, 03:58 AM
Diesel_Brad
I have one but I am sure shipping would make it not worth while
  #41
Old 10-25-2015, 07:00 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
I want to replace the rear U joints and the rubber around the mid shaft carrier bearing is rather torn. Maybe it is contributing to the shacking?
So I locked in the front hubs and removed the rear drive shaft and went for a drive. Other than some front wheel drive quirkiness in tight turns there was basically no change in the shaking at about 65 mph.
I wonder if there is a frame stiffening that is a little less than Brad's badassery level of full plating.
  #42
Old 10-25-2015, 08:08 PM
Action4478's Avatar
Action4478
Action4478 is offline
I had the same thing since 06 at highway speed on new tires . Finally replaced the tires & they were properly balanced . Smooth at 90 MPH
slinginsaws
02-18-2015 07:18 PM
Corrupt Silence
02-12-2011 12:24 PM
Solomon_Man
12-03-2010 09:32 PM
canadianredneckf150
09-24-2007 07:56 PM
JeremyF1504x4
1997 - 2003 F150
01-16-2007 09:01 AM
Quick Reply: Thought it was shaking, but the frame is bending…with video
