Sloppy Colom Shifter Repairs?
Jason
Upper shroud in place, lower removed for other reasons, 2 photos:
Upper Bushings, straps and Torx bolt heads, shroud removed:
Lower bushings, straps & Torx bolt heads, barely visible under the cluster:
To remove upper shroud ignition cylinder needs to be removed first. There is a ball detent or catch in the cylinder assembly, looks like this:
That ball detent is located on the underside of the column superstructure, thusly:
Note: Instrument cluster trim removed for other reasons, not necessarily required for this maintenance.
Alice something to consider when seeking help here---always post your van details each time. Year, motor, suspension (E150, E250 etc). On occasion that info is needed to best help without asking for it. If that info is in your signature keep in mind not everyone (me for example) has their FTE pages set to include those in the forum threads.
Anyway hope this helps-----if not ask again and we'll try.
Those bushings are available from your local dealer, if one is near you.
that's the plan foe today actually. I am just not sure how I can do the repair myself. my t30 tool just doesn't make it to the front strap and would have no clue how to reach the rear ones. only way I see is dropping the column from the dash but being a srs system kind of makes me uneasy to do that. going to find out mechanic cost today too. but maybe I can get it fixed in 2 weeks after my tags. but not holding my breath. about 14hrs this week and less last week being sent home sick. dammed if u do dammed if you don't.
99 e350 ext 7.3 turbo
#28
Appology
Public apology:
Besides being a mostly peaceable sort, my belief is that if you find fault with anyone, you should also be prepared to recognize merit in that person. Some time back, JWA and I annoyed each other (the specifics are too trivial to recount here). I'm sorry it happened, but especially so because in looking at this very useful thread it's obvious that JWA has made a special effort to get the O.P.'s questions answered, not to mention help anyone in the future who has similar problems. This level of input is what can make this medium a valuable source of info. So, JWA, sorry for my part of that dumb little exchange of a couple of months ago (if you even recall it). And thanks for the good effort here!
--Smitty
--Smitty
#29
My efforts here are somewhat altruistic but only to the point helping someone avoid mistakes or learning curves I've endured since owning a Ford E-Series vehicle. I hope to be consistent in that effort even if it doesn't please everyone or occasionally disagrees with another's opinion.
#30
Adding some photos for Alice's benefit or anyone else looking in contemplating this job...........
There are four nuts holding the column superstructure to the body, a few of them shown here. Pay attention to the column orientation as these photos show it from top looking down opposite too:
This one shows a piece that would have to also be removed in order to drop the column while still connected to the steering shaft and resting the steering wheel on the front seat:
Any questions don't hesitate to ask!
jimhardc
01-19-2011 11:05 AM
mustangcrew
1997 - 2003 F150
05-13-2008 06:06 PM
buffalobob
12-03-2007 02:00 PM
