Location of the Camper Special emblem on a 68-69 F-250 ?
The Emblems were taken off along time ago for some repair and I need to find the location again . I know it was down on the bottom of the front fenders but I can not find the old holes . If someone with a 68-69 F-250 Camper Special could measure the center where the -S- crosses the straight line in the emblem , then to the door edge and down from the side trim to get a location . I'll then be able to drill and anchor with the Emblem Barrel Clips . I made a plastic template that I can tape on to locate the other drill holes . Thanks T.
Location of Camper Special script nameplate 1967/68 & 1969
What year is your Camper Special?
1967/68: Camper Special script name plate located on the R/L sides of the cowl panel.
1969: Camper Special script name plate located at the bottom of the R/L front fenders.
1968 F100/350 with 390: The only emblem at the bottom of the front fenders: C6AZ-16228-E Right & C6AZ-16229-B Left .. 390 Emblems / Reproduced
If your Camper Special is a 1969 w/a 390, these emblems are located in front of the Camper Special script nameplates.
This 390 fender emblem was introduced on 1966 Galaxie/LTD, also used on 1967 Galaxie/LTD
Besides this 390 emblem, there were 352 - 427 - 428 versions for 1966/67 Galaxie/LTD
smittysan
17
06-28-2020 10:57 AM
masterbeavis
02-11-2008 06:35 PM
