Fuel Gauge does not work
Hi everyone and welcome to FTE newbies! I had the same problem. As jrs_big_ford_f150 says.. It may be a wire has corroded and broken off. I wasn't going to run my tank out of fuel and remove it for a wire, so I used an alligator clip spliced the wire to it and clamped it back onto what was left of the terminal on the sending unit. You guys may be lucky and still have a full terminal and you can splice on a new female connector. Good luck and get back to us.... We're nosey!!! Talk with you guys later....
Stonesetter1
09-05-2015 07:23 PM
AKHunter93
08-14-2015 10:56 PM
Pete Roberts
02-24-2011 07:29 PM
