E-150 won't start
Old Jul 29, 2003 | 04:53 PM
hwoods3's Avatar
hwoods3
E-150 won't start
1995 E-150 9 passenger Club Wagon. Has been running fine. This morning, with no prior warning, turns over but will not start. Will start with starting fluid so I am assuming I have some sort of fuel problem.
Any ideas, don't know what to do first.
Thanks in advance!
Hwoods3
Old Jul 29, 2003 | 05:18 PM
PA F150 4X4's Avatar
PA F150 4X4
E-150 won't start
Fuel Filter
Fuel Injector Cleaner
Old Jul 29, 2003 | 06:38 PM
pfogle's Avatar
pfogle
E-150 won't start
pull the passenger side kick panel and press the button on the inertia switch. Someone prolly bumped the van with the lawnmower.
Old Jul 29, 2003 | 08:29 PM
hwoods3's Avatar
hwoods3
E-150 won't start
I know I sound like an idiot (probably because I am) but where do I find the passenger side kick panel?
Thanks! if this is not too stupid a question!
hwoods3
Old Jul 29, 2003 | 09:27 PM
Scooter29's Avatar
Scooter29
E-150 won't start
Hey there hwoods3 and welcome to the Forum! When you enter the passenger side of the van, it's the plastic panel your right foot seems to always kick when you get in and it's always resting near it, because other than the dashboard, there's no place else to put your feet! A little cramped in that area....
Anyways, It'll take a bit of umph to get it off and on, but the reset switch will be quite visable when you remove the panel. If that doesn't solve the problem, I agree with PA 150 4X4. It's probably the fuel filter. Good luck and get back to us with the results.... Talk with you guys later....
Old Jul 29, 2003 | 09:51 PM
c96drumm's Avatar
c96drumm
E-150 won't start
In my E-150 you don't have to remove that panel, the switch is just above the top of it.
