c6 transmission
c6 transmission
Was wondering if this would work with my 4.9l l6 motor in my 66...
Ford small block C6 transmission
Thats if its still available
Looking to swap over from the 3 on the tree to an automatic
Seller claims this 'small block' C6 was in his 1968 Mustang, but if it was, it was swapped in.
C6's were available in 1968 Mustang's, but only with 390's and 428's.
1979 was the first year that FoMoCo offered the C6 in cars with the 302.
1978 was the first year that FoMoCo offered the C6 with 300 I-6 in F100/350's & Econolines, 302 in F100/150's, 1979 E100/150 302.
Bell housing = M/T / Converter Housing = A/T .. but on a C6, the converter housing is made as part of the transmission case.
1978 was the first year that FoMoCo offered the C6 with 300 I-6 in F100/250's & Econolines, 302 in F100/150's, 1979 E100/150 302.
Now im alittle confused with the last part.... mt=bell at=converter... i know he mentioned auto trans but the referes to it having a bell house.... im assuming he meant small convert housing instead of bell?
I plan on addressing the power steering issue once im able to tear into the suspension. Want to swap the front end parts to a crown vic front eventually. Plans are focused on getting an auto trans swapped in. As far as an auto column, do you have any ideas where i can find one that doesnt cost an arm and a leg like these aftermarket companies lol
Thats what i figured... so i assume since it has the small convert housing that i wont have an issue in mating it to my engine? I emailed him to see if he had more info on the trans. I found a c4 trans that was mated to the same motor as mine but out of an early 70s f100 but made an offer and all i got was i would think about it and i followed up but got nothing so figured i move on. I think he was trying to sell motor n trans as a whole but whatever.
So the guy emailed me back about the c6 and he doesnt know what motor it was mated to since the mustang had no motor just the trans. Also said the mustang was coded to originally have a c4. I asked him if he had any numbers off the trans to help pinpoint what the trans was originally mated to etc
TRANS ID tag (see below) located under one of the bolts that retains the servo cover to the case. But...by now, it could be missing.
So using good old google it appears from the website below that the trans maybe from a 70s f150 mated to a 351.... if im correct would this still be an option to match up to my 4.9l 300ci l6?
1973-1979 Ford Truck/Van Automatic Transmission Application Chart - FORDification.net
Scroll down to the 5th listing in 1979 E Series (Econoline) chart.
sullyda1
06-16-2020 01:04 PM
Yachtin
08-08-2004 12:46 PM
