Troubleshooting Light Mounting
Old 06-01-2015, 08:15 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Was this mounted using the same washer head phillips trim screw like is used to hold the cowl on and the cowl to hood seal?
Old 06-01-2015, 09:13 PM
ctubutis's Avatar
ctubutis
ctubutis is online now
No, not that small; IIRC they used larger, phillips-head (or maybe 8 or 10 mm hex) sheet metal screws.
Old 06-01-2015, 09:26 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Ah ok, I guess I will need to do some research in my parts and illustration guide to see if I can find what the specs are and I will just order some.
I am currently trying to find a 1142 LED bulb that will fit under the clear bulb cover. I also need to order a bulk pack of BA9s bulbs in Green and Warm White as well.
Too bad the truck at work doesn't have one I could use that as a way to find a close match.
Old 06-01-2015, 09:41 PM
ctubutis's Avatar
ctubutis
Looking up hardware like that in the parts manual sucks; I'd match the thing up to where it's supposed to mount (locate the pre-drilled holes) then get something from the local hardware store that will work.
Old 06-01-2015, 10:01 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
That's what I ended up doing with the 82 at work that I am putting back together I just find what will work and threaded it in where need be.
That is a easy problem for me, my problem is locating the correct LED bulb I want for this light its a BA15D base but the two pins on the bottom one is + and one is - but most of what I am finding is 1157 style bulbs where both pins are + and the side case is -.
The few I did find they are 1.8" and it wont fit under the plastic cover as the oem 90 series bulb is 1.44" max over all length. I believe I could get away with one up to 1.50" but that is at most.
85MOTORSPORTXLT
17
12-19-2015 09:51 AM
PJ-Hunter
04-06-2014 09:45 PM
FarmingF250
08-12-2012 06:39 PM
NorCalBusa
1999 to 2016 Super Duty
12-27-2010 03:54 PM
CanadianSmokie
10-26-2007 04:30 PM
Quick Reply: Troubleshooting Light Mounting
