how to properly break in a new engine???
hello,
this weekend I will hopefully finish installing a rebuilt engine into my 78 f250. The motor has never been fired, and I just want to make sure I'm doing everything right.
So, What oil should I use to break it in?
Any special additives I should put in to help break everything in?
how should I drive it, and for how long?
I've done a lot of reading on here about what oil people prefer, and I'm leaning towards the Diesel oil shell Rotella, but not sure what weight, and I'm still open to others, so what does everyone recommend? Its probably worth mentioning that I live in northern Minnesota, so I might be using different weight oil in the winter. I like running synthetic oil in my car in the winter since it gets so cold (-40 f isn't uncommon), but not sure if synthetic is good in these older motors?
thank you in advance for any help!
Tyler.
Tyler.
If you are using a new cam and lifters use the additive that the cam manufacturer recommends/supplies.
Otherwise I use a nationally recognized brand of 10W-40 with a quart of synthetic 10W-40 of the same brand.
Good to go in excess of 7000 RPM. No oil related failures in 50 years of racing/rod building.
The synthetic can prevent this from properly taking place.
Once the break-in is done though, by all means...
