Installing New Brake Hoses
Called Crown and had them make up a set of their DOT approved 5 piece hose kits which includes the rear caliper hoses. $190 covered it, took about a week to make them up to delivery. They look very off road worthy.
I was looking for torque specs on the flex hoses and came up blank.
I believe the brake line caliper banjo bolt for the rear is 26 ft. lbs.
but I don't know if this correct and if it also the same for the front .
The torque specs at the flexible hose to the rigid brake line is also a guess. I guess when it stops leaking it's tight.
Can anyone shed some light on the correct torque values for the various hose connections?
thanks guys.
will attempt to tackle this hose R&R this weekend.
I had this filed away but forgot about it, if anyone wants to save the info for later, I modified it a bit making it more printable friendly.
Don't think this is in the tech folder.
Brake Specs
2005 F-Super Duty 250-550 Workshop Manual
SECTION 206-03: Front Disc Brake
Torque Specifications
Description: (Nm.) / ft lb.
caliper bolts (F250, F350) (76Nm) 56 ft lb.
caliper flow bolt w/crush washer (48Nm) 35 ft lb.
caliper anchor plate bolts (F250, F350) (225Nm) 166 ft lb.
Wheel hub extender nuts (176Nm) / 130 ft lb.
Brake disc shield screws (11Nm) / 8 ft lb.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
SECTION 206-04: Rear Disc Brake
Description: (Nm) / ft lb.
Brake caliper bolts —
F-250, F-350 single rear wheel (35Nm) 26 ft lb.
Brake caliper flow bolt (35Nm) 26 ft lb.
Brake caliper support bolts (137Nm) 101 ft lb.
Disc-to-hub bolts (121Nm) 89 ft lb.
Brake caliper anchor plate bolts —
F-250, F-350 single rear wheel (275Nm) -203 ft. lbs.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xx
SECTION 204-04: Wheels and Tires
Description: (Nm) ft lb.
Spare tire carrier bolts —
(20 Nm) 15 ft lb.
8-Lug M14 wheel bolts —
F250/350 (224 Nm) 165 ft lb.
Brake Specs
(20 Nm) 15 ft lb.
