Sponsored by: Auxito
Torque spec help
Old Aug 12, 2009 | 10:17 AM
FordLou's Avatar
FordLou
Torque spec help
Hi guys,
Could anyone help me with the following torque spec info for 1 '99 F-150, 4wd, supercab please:
1) aluminum wheel lug nuts (5 lug)
2) brake caliper to steering knuckle
3) any other specs related to doing front brake pad replacement
Thanks for anyone who can spare the info.
Take care,
Lou
Old Aug 12, 2009 | 05:41 PM
ls973800's Avatar
ls973800
If you have the 12mm lug nuts, the torque spec for the wheels is 100 FT LBS
14 mm lug nuts, which I believe started being used sometime around 2000 or 2001, the torque is 150 FT LBS
I only have the 2003 Workshop Manual, but the torque values should be the same for your brake parts.
Front disc brakes
Brake hose bolt 23-29 ft lbs
Disc brake caliper bolts 21-26 ft lbs
Disc brake caliper anchor plate bolts 136 ft lbs
Brake disc shield bolts 7-10 ft lbs
Rear disc brakes
Brake caliper bolts 20 ft lbs
Caliper flow bolt 23-29 ft lbs
Disc brake adapter bolts 80 ft lbs
Old Oct 24, 2009 | 12:34 PM
Bobasaurus's Avatar
Bobasaurus
Great information. I used it today.
Old Oct 24, 2009 | 01:05 PM
FordLou's Avatar
FordLou
Many thanks for this info. Made the job complete. Was able to move on to the next project. (Makes the wife happy!).
Old Oct 24, 2009 | 08:15 PM
ls973800's Avatar
ls973800
After having used this forum for several years and getting very useful information, I am glad I was able to "pay it forward" a little bit.
ohioescape
Escape & Escape Hybrid
Jan 15, 2011 06:51 AM
murph1
2009 - 2014 F150
Nov 27, 2009 03:15 PM
61 uni
Feb 20, 2009 04:15 PM
rmo1
May 21, 2007 08:44 PM
spinellib
Aug 13, 2003 09:25 PM
