Brake Torque Specs.
This should cover '05 up to '11 MY, IIRC.
Front Disc Brake-
Torque Specifications:
caliper bolts (F250, F350) (76Nm) 56 ft lb.
caliper flow bolt w/crush washer (48Nm) 35 ft lb.
caliper anchor plate bolts (F250, F350) (225Nm) 166 ft lb.
Wheel hub extender nuts (176Nm) / 130 ft lb.
Brake disc shield screws (11Nm) / 8 ft lb.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Rear Disc Brake
Brake caliper bolts —
F-250, F-350 single rear wheel (35Nm) 26 ft lb.
caliper flow bolt (35Nm) 26 ft lb.
caliper support bolts (137Nm) 101 ft lb.
Disc-to-hub bolts (121Nm) 89 ft lb.
caliper anchor plate bolts —
F-250, F-350 single rear wheel (275Nm) -203 ft. lbs.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xx
Wheels and Tires
Spare tire carrier bolts (20Nm) 15 ft lb.
8-Lug M14 wheel bolts —
F250/350 (224 Nm) 165 ft lb.
