AC/Heating
AC sometimes only works for a minute, do you mean you can feel it blows cold, or you observe that the AC compressor runs for a minute?
From your post, I assume it's only the temp regulation that doesn't work, and that the distribution (i.e. defrost, vent, floor) works as it should. In that case, the first thing to check is the actuator for temperature. I'm not sure if this has the same issue as the 2nd gen on the blend door actuator, but it should be easy enough to diagnose apart from getting into that tight space.
Check this video:
It's part 1, but I'm sure you can find part 2 from there.
Check this video:
J33P4L1FE
1997-2006 Expedition & Navigator
05-20-2014 08:59 PM
scottskingdom
12-02-2011 04:25 AM
