Last Summer we had amazing AC in the Expe, this summer as it starts to warm up we have noticed that it isnt cooling the car down at all...
So far this is what i know...
That set to 60F it blows the same temp as outside, set to 90 and it blows HOT!!!
I did the OFF/Floor test and it came back 888 (No problems)
The Lines at the firewall are ice cold.
The rear AC is warmer than the front
Rear AC is blowing at 95
Front AC is blowing at 80
It is currently 80 outside
And everything is set to max AC
Does turning the temperature **** in the front or back effect the air temperature coming out of the vents at all? If not your front could have a broken blend door and the rear a bad blend door actuator.
