"Stumble" at light throttle
I just got a 95 F150 Eddie Bauer. 5.8L, Automatic. Nice truck.
I've encountered a few problems with it. Nothing too major so far. This one has me stumped.
At light throttle (i.e. taking off from a stop), there is a hesitation. It's seeming like the truck wants to stall out. I have noticed this happening before and after it warms up.
When I take off and give it a little extra throttle, it doesn't stumble.
I changed the fuel filter today (needed to be done), and it hasn't changed anything.
I have noticed an exhaust leak growing steadily worse by the day. It sounds like its coming from the passenger side manifold.
No CEL, and the truck starts right up every time.
Ideas?
My theories are as follows: Plugs and wires, EGR, transmission, catalytic converter.
Ideas?
If no vacuum with the electrical connector removed then you have the computer modulating the EVR when it is not supposed to..so bad computer or some moron has wired a continuous ground to the EVR (the computer does this when it is programmed to do it).
Be aware you will probably trigger a Check Engine Light and code by pulling the electrical connector. Not a big issue, just a heads up to not panic.
blackbast
1997-2006 Expedition & Navigator
04-23-2005 10:07 PM
reeve302
09-15-2004 01:24 PM
