Hesitation when applying full throttle....
Old Apr 22, 2005 | 11:03 PM
blackbast's Avatar
blackbast
Angry Hesitation when applying full throttle....
When I apply full throttle or try to shift into overdrive, I get hesitation. I'm thinking that it's clogged cats. When the truck is idling, I can hear whistling from the middle of the underside. Does anyone have any suggestions on what this could be?
Old Apr 23, 2005 | 01:04 AM
Monsta's Avatar
Monsta
Sit. Stay.
Well, I'd definantly crawl underneath to find the actual cause of the whistling.
Full throttle hesitation (as you describe) can be a number of things ranging from a partially plugged up fuel filter or air filter, emission control related part or even the transmission or torque converter.
How many miles are on the truck and what, if any, mods have you done to the powertrain?
Old Apr 23, 2005 | 02:08 AM
blackbast's Avatar
blackbast
I'm at 111K. This started happening after I removed/cleaned the throttlebody for the p0401. I have not modified the powertrain at all. I'm getting p1450 now so I'm gonna change the fuel filter and check the lines while I'm under there.
Old Apr 23, 2005 | 08:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
Make sure the gasket behind the throttle body wasn't compromised when you did you R&R.
Old Apr 23, 2005 | 10:07 PM
blackbast's Avatar
blackbast
I replaced both upper and lower gaskets when...
I removed the throttle body. I'm gonna try to do the repairs on Thursday.
FoxFord33
Feb 1, 2017 05:53 PM
2012Z06
Sep 21, 2016 11:40 PM
zottyzot
Jan 2, 2011 01:33 PM
Ricohman
Modular V10 (6.8l)
Oct 2, 2010 03:14 PM
jayhawkfan
1983 - 2012 Ranger & B-Series
Jan 31, 2007 10:58 AM
