1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F450 OBDII port is dead
Old 05-04-2015, 04:32 PM
KMcCullah's Avatar
KMcCullah
KMcCullah is offline
Hi guys I'm new around here. Always been a Ford guy.
I did a few forum searches and can't find my solution so here's one for the vast braintrust here. Google is NOT my friend in this instance.
I found this truck on Craigslist. 1999 F450 6 speed with a pto on the tranny and a dumping flatbed. Damn cheap but it needed a new engine. 7.3 powerstroke. So I've been working on this truck for a month now. Put in a low mile used 7.3 and got it running now. The plan is to flip it and use the profit to buy some high flowing heads and solid roller cam for the 504 FE I'm building for my 1972 Highboy.
The only thing I have left to fix is the ABS light is on. I figure one of the wheel sensors is bad. I've dealt with this issue before. To find out what ABS codes are present I plugged in my OBDII scanner. It won't power up. I thought maybe it was dead so I plugged it in to my truck and it works great. Dug out my owners manual to my truck (it's a 1999 F250 7.3) I didn't get the owners manual to the F450. I see fuse #3 is a 20A fuse that powers the OBDII port and the cig lighter. Checked the cig lighter and yep it's dead too. I pulled the cover off the in cab fuse box and it does NOT have a #3 fuse. The slot is empty, nothing for a fuse to plug into. So obviously the fuse schedule is different from the F250 to the F450. After several hours researching the web, I'm stumped. Where does the OBDII port and the cig lighter get power from in a 1999 F450? I've checked every fuse and they are all good. No slots are empty.
Old 05-04-2015, 05:11 PM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
Old 05-04-2015, 07:12 PM
KMcCullah's Avatar
KMcCullah
Thanks for the link Larry
Originally Posted by Just Strokin
Page 147 shows fuse #3 is for the cig lighter/OBDII. The F450 I'm dealing with didn't come with a fuse #3 under the dash unfortunately. I'm going to look thru the fuses under the hood again. I'm missing something obvious here. Like a blown fuse............
Old 05-04-2015, 08:59 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
The service diagrams for all the Super Duties is the same. F3 is the cigar lighter and power port.
Since 99 was the first year for the SD line, there must have been some variations that didn't get documented and you've ended up with one of them.
Old 05-05-2015, 08:53 AM
brian42's Avatar
brian42
brian42 is offline
Had the same problem a while back. My OBDII Bluetooth transmitter stopped working and I thought it died. Checked the fuse and it was blown. Replaced it and all was good. I've had a few fuses go out for no reason. Many of my fuses are 12 years old so I have chalked it up to age if there's no apparent reason. Your owner's manual will have a list of the fuses. If you don't have one you can Google it and you should be able to find a .pdf version you can download for free.
Old 05-05-2015, 11:04 PM
dkf's Avatar
dkf
dkf is offline
Fusing the OBDII power with the cigarette lighter was a hair brained thing to do. Mine blew once when the cigarette lighter was in bad shape. I don't use the cigarette lighter, I'm blaming that one on my old man.
Old 12-21-2015, 11:36 PM
F350SuperCab4x4's Avatar
F350SuperCab4x4
F350SuperCab4x4 is offline
Sound like someone changed your fusebox. This is what happened to me on my 2001 F550. some wiring was burnt up and someone changed the fusebox on me and somethings didn't work. call the dealer parts guy and give them your VIN number and see what fusebox comes back. Then look at the numbers on yours. I'll bet you have the wrong one. after i got the correct one everthing works on mine.
ithaca1230
04-08-2017 02:07 AM
sanders46
05-03-2011 07:09 PM
thordehr
05-14-2010 04:25 PM
mmmPowerStroke
01-04-2006 07:14 PM
nasa-hvac
1997 - 2003 F150
03-12-2005 06:20 PM
Quick Reply: F450 OBDII port is dead
