Metal inserts for installing badges/emblems
Old 04-30-2015, 12:38 AM
Ira Brown's Avatar
Ira Brown
Ira Brown is offline
Can anyone tell me where to get the small metal inserts for attaching badges/emblems.
It is time to put my emblems/badges back on my 78 F150. But I damaged and lost the metal inserts that go into the holes in the body into which the badges/emblems attach.
I cannot seem to find a source for buying them.
Thanks !
Old 04-30-2015, 03:10 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Ira Brown
Can anyone tell me where to get the small metal inserts (barrel clips) for attaching badges/emblems.
When these emblems were available from Ford, they came with the barrel clips. I looked in Carpenter's 1967/79 catalog, he also supplies the barrel clips with the emblems.
There are several different sizes, automotive paint supply stores, where body shops buy their supplies could have them.
Old 04-30-2015, 03:23 PM
orangeford's Avatar
orangeford
orangeford is offline
Bronco graveyard sells the clips without the emblems if needed. They list them for different emblem locations but I think they are all the same. Search barrel clips on their site and you will find them...
Cowl Emblem Barrel Clips 73-79 (one emblem)-Broncograveyard.com
Old 04-30-2015, 06:04 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,348 Likes on 2,490 Posts
FYI they are not metal, they are plastic...x2 on JBG to get them.
Old 04-30-2015, 10:44 PM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
emblems
I have a question about the emblems.When buying new emblems are they like the emblems of the past ,pot metal.Or are they plastic now?
Old 05-01-2015, 07:23 AM
77&79F250's Avatar
77&79F250
Yes pot metal/cast?? and the pins are still very fragile IMO.
Old 05-01-2015, 12:16 PM
OrangeRanger's Avatar
OrangeRanger
OrangeRanger is offline
Yeah my question too is if you can easily put the new emblems on without difficultity because you guys say the new inserts are plastic? Are they durable? Remember Im young give me a break
Old 05-01-2015, 01:55 PM
hickory1991's Avatar
hickory1991
hickory1991 is offline
I just installed 2 NOS F-250 emblems that had 1 insert and 2 speed-nut or pal nut, whatever you call them. The shanks can be reached from the underside of fender. The barrel insert went in the hole closest to the cab.
Old 05-01-2015, 05:10 PM
77&79F250's Avatar
77&79F250
On the 73 to 74 or 75 yes they are bolted to the fenders well below the cowl. On the 77 to 79 they are push in mounted in the cowl and in the plastic barrel inserts that are also just push in installed.
WarriorWithin
04-12-2022 05:20 AM
LARIAT 85
09-17-2011 11:40 AM
Dodge/Cummins
06-27-2008 05:12 AM
Outlaw08
1978 - 1996 Big Bronco
03-13-2005 12:33 AM
Little Bro
05-22-2004 11:23 PM
Quick Reply: Metal inserts for installing badges/emblems
