2003 Window Wiring codes
None of the windows will function. Took off the door panel wiggled the wiring harness and the windows would function. Fortunately I got them all up.
Now with nicer weather it would be nice to have them working.
I assume I have a broken wire leading to the master switch in the driver door.
What would be the color code that is likely broken.
Is it only the driver's Master window switch that doesn't work, or do none of the windows switches work either when the master switch doesn't work?
My first suspect would be the Light Blue/Black wire (terminal 6) which is the main power for the master window switch. The only other wire that would be common to all the windows would be the black ground wire (terminal 2). If either of these wires were open none of the power windows would work.
-Rod
-Rod
GAGDAD07
13
06-26-2019 09:32 AM
Lukes66
06-21-2013 09:45 PM
nojeffgordon
03-09-2010 09:37 PM
vicv
05-01-2005 04:26 PM
