Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Key stuck in ignition
Old 04-01-2015, 03:01 PM
86f250xl's Avatar
86f250xl
86f250xl is offline
Key stuck in the ignition of my '86 f250, how can I get it out of the ignition?
Old 04-01-2015, 07:52 PM
Q ball construction's Avatar
Q ball construction
Q ball construction is offline
i think your actually looking for a locksmith?
Old 04-01-2015, 11:05 PM
86f250xl's Avatar
86f250xl
86f250xl is offline
I was hoping that there was a way to get it out muself
Old 04-01-2015, 11:14 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Will the key turn ? can you start and turn off your truck ?
You can try some WD40 or such .
You could also replace the switch . Cheep and easy to do .
Old 04-01-2015, 11:26 PM
86f250xl's Avatar
86f250xl
86f250xl is offline
Key turns, can turn on and off just can't get it all the way back to the position at which it releases
Old 04-02-2015, 06:15 AM
fellro86's Avatar
fellro86
fellro86 is offline
Is the truck a manual transmission? I don't know what you know, so I apologize if it seems dumb but if it is a manual transmission you have to push the button on the bottom of the column to get it to turn all the way back. If that isn't the issue, you likely need to get the ignition switch off and it hopefully will move the rest of the way. Since the key is in the lock, you can also remove the whole lock cylinder. That is better than when you have no key, as if memory serves, you have to turn the key and cylinder forward to remove it. I would have to look up the procedure, as it has been a while. I would check out the ignition switch though. You have to drop the column down a bit to get to it, as the switch itself is operated by a rod from the lock cylinder and is mounted on the top of the column under the dash. 2 little bolts allow it to come off.
RBerry9511
02-07-2020 04:31 PM
TexFinn
1997-2006 Expedition & Navigator
19
02-08-2015 09:09 PM
chrishouse4
11-23-2006 08:49 PM
raineytx
11-22-2005 11:54 AM
mingiz
1999 to 2016 Super Duty
09-06-2005 02:28 PM
Quick Reply: Key stuck in ignition
