automatic hubs
Does your '00 have the pulse vacuum hublocks (PVH) 4WD engagement system? If so, you might be better off installing a pair of aftermarket manual lockers from AVM/Rugged Ridge. I see them on Amazon and eBay.
I don't think I've seen an aftermarket OEM-style Ranger PVH hub. I think you could only get them from Ford, and maybe not even now.
it does have the pulse vacuum hublocks changed i have changed the passenger side one
and still clicking i was told that the hub 4x4 hub was the problem . in 4x4 high not much noise or clicking but in 2wd lots of rattle clicking . cv shot? anyone here ever have this problem . when changing the hub cv seemed that it was loose it is held in by a c clip not a nut but not sure if it should have that much play . rule out wheel bearing ?
70runner
12-05-2010 10:14 AM
