99 Expedition - No Low-beams
Left low beam went out about two weeks ago, and the right one went out this weekend. Replaced the right headlight so far but still no low-beam. Both high beams work fine, and both low-beam fuses are good.
Left fog light is also out, but haven't changed it out yet.
Ideas?!?
Ideas?!?
Once the left and right low beam wires leave the fuse box they have no common point between them. So the problem is at the fuse box, or you might have a critter eating your wiring harness. I know you said the fuses (26 & 28 right?) are good, but did you actually test for power on both sides of them when the low beams are on?
