Coil gets hot then bursts
Well this is my 2nd thread today, iv been working on my truck over the weekend. I walked outside today and seen smoke come outa the engine. So i popped the hood and seen the coil blew up. I thought it was a bad coil so i went to buy a new coil and installed it. No the key was not left on. Then not a half hour later the new coil blew up again! So i returned it for a new one, and i also bought a new ignition switch and lock cylinder. I disconnected the battery put in the new coil and ignition system. So now i connected the battery and 1 min later the coil was already getting hot! I disconnected the battery, and i disconnected all the wires from the ignition switch. Connected the battery and 1 min later the coil is hot again. Im probably going to have to take in to a mechanic, but not before i asked you guys. The truck is a 1966 f250 with a 352. Also when i put the battery cable back on the battery it sorta sparks. But when i take the positive and negaitive wires off the coil the battery does not spark when i put the battery cable back on.
Ok i swapped the front wires on the relay with the battery cable on and after 5 mins the coil di not heat up. Then i tried starting the truck up and no ignition. So i swapped the wires on the relay back to what they were, and one of the wires as i put it on the relay sparked. I put the battery cable back on and the cable did not spark as i put it on the battery. And so far so good. It seems like when the relay wire sparked that somehow stopped the battery cable from sparking, and currently everthing is working, we even started the truck up and ran it for a while.
We have the wire from the distributor to the -neg side of the coil. And the coil is in the round metal bracket. All connections are good. Is there another ground?
bryanmartin
09-07-2015 05:24 AM
Jpett
11-03-2013 04:35 PM
