Error Codes in 2001 F450 7.3 Diesel Thanks Kimberly
Hi,
I have a 2001 F450 7.3 Diesel
I am getting two error codes:
P0743 Torque Converter Clutch System Electrical
P0741 Torque Conerter Clutch System Performance/Stuck
What do these codes mean?
Do I need to change my torque converter or maybe just the torque converter control solenoid?
If it is the solenoid, how do I change a solenoid?
Thank you so much for your help
xoxo
Kimberly
xoxo
Kimberly
on
Is the Torque Converter not locking? Do you see an RPM drop or feel the lock up? Can you give us more information about its symptoms? The P0743 is pointing to a connection/wiring or solenoid issue. The TCC solenoid is part of the Solenoid VB and would need to be replaced as an assembly if defective. Tell us more before throwing parts at it.
Hi,
xoxo
Kimberly
xoxo
Kimberly
echo=on
Any Car Code OBD-II On Board Diagnostics Phase 2 Vehicle Media Communications. Here are a few in alphabetical order.
AutoEnginuity
Bosch
Delphi
Diablo Sport
Edge
Ford DIS
Hickok
NGS
OBDLink SX
OCT
Snap-On
TorkPro - Android Based PC Interface w/ ELM27 Bluetooth
Ps: You get what you pay for when buying diagnostic equipment.
echo=off
This will allow you to monitor what's happening while driving the vehicle.
TheTowingCowboy
06-26-2009 10:24 AM
jm03679
02-09-2004 10:54 PM
