e99 7.3 cackle?
Old Feb 27, 2015 | 07:03 PM
keiseldiesel's Avatar
keiseldiesel
e99 7.3 cackle?
What is the best fuel regulated return system? Fuel bowl delete or not? Im trying to get rid of this annoying cackle. Thank god for tax returns haha. Any tips will be helpfull. Thank you.
Old Feb 27, 2015 | 08:47 PM
rcgtsport's Avatar
rcgtsport
hello and welcome to fte. I have riffraffs frx, hpx and driven diesel pre pump filter. look for Hutch, Harpoon mod. all this took care of it on my truck.
Old Feb 28, 2015 | 04:21 AM
Tugly's Avatar
Tugly
Hutch and harpoon mod is the call. Air in fuel should be prevented, not removed. FRx and regulated returns don't protect the fuel system from...
  • pump cavitation
  • reduced pumping efficiency
  • diminished fuel delivery or total loss thereof
FRx can only remove air from the fuel rails after the air has had a shot at your injectors - but it's still good to eliminate deadhead.
Old Feb 28, 2015 | 09:25 AM
bigreentruck's Avatar
bigreentruck
What is "cackle"?
Old Mar 6, 2015 | 10:34 AM
F5504ED's Avatar
F5504ED
Good article, "Hutch & Harpoon" mod;
Welcome to guzzle's In-tank Hutch Mod Web Page
I have had to pull and disassemble my pick-up assembly four (4) times to clean my bronze 410 screens. Fortunately, the service bed on my 550 is high enough so that I can crawl under my truck and access the Fuel Pick-up hatch by leaning front to rear, over my rear axle.
Of course, "Murphy" always requires this service interruption at the least convenient occasion.
I am going to add this Mod to my list.
Thanks "guzzle" !
Old Mar 6, 2015 | 07:12 PM
keiseldiesel
here is what it sounds like. it gets louder as the engine warms up this is probably the loudest it has been.
thanks for any replies
Old Mar 6, 2015 | 07:36 PM
keiseldiesel
And also if i open that valve cover and its just a normal AB injector. can i replace it with a AF (LL injector) and that will cure this problem.
Old Mar 6, 2015 | 08:03 PM
bigreentruck
Sounds like mine
Being new to diesels (November), and having a 2000 7.3, the truck is noisy on the outside, and I just figured that that sort of sound was to be expected from the older model trucks. Your truck sounds about like mine. Should I not expect so much "diesel machinery noise"?
Old Mar 6, 2015 | 08:25 PM
keiseldiesel
Truck is gonna be loud but when I hear something that sounds like a mechanical issue. I get worried. but most of the time it's just cackle... if I'm not mistaken "cackle" is air being forced in the injector and makes that noise. But before I start doing fuel mods. I'm just gonna pull my valve cover off and see if my #8 injector is working properly and to alsoffers see if it is a long lead injector. The long lead injector was made by ford to cure cackle.
Old Mar 6, 2015 | 08:27 PM
keiseldiesel
  • pump cavitation
is it better to just remove the filters in the tank? I've seeNight it both ways just wondering how u did it.
ExPACamper
Jul 24, 2015 07:38 AM
lght1
Jun 5, 2013 03:52 AM
MauleOne
Sep 3, 2012 11:26 AM
jirwin
Nov 4, 2010 09:43 AM
Mark3682
Jan 27, 2004 01:25 PM
