New IP & Injectors!! + Fuel Leak
Old 02-24-2015, 02:55 PM
jmuenchow's Avatar
jmuenchow
jmuenchow is offline
I replaced my injectors alone with my injection pump on Sunday and boy it made a HUGE difference. The truck had 225k miles on it and it was the ORIGINAL pump! How I was able to drive it everyday beats me but that's besides the point.
I have a fuel leak from the steel line that goes from the fuel filter to the pump itself. Looks like there are rubber gaskets that go on these lines and the ones that are there are messed up. Is there any way of repairing these? Does anyone have one I can buy off of? Where can I buy it?
Thanks,
Joshua
jmuenchow's Avatar
jmuenchow
ALSO: this is my DD so the faster I can fix this the better!
Old 02-24-2015, 06:02 PM
Phy's Avatar
Phy
Phy is offline
Those are called "olives" here. If you change the subject line of your first post to something like "Where can I get new olives for my fuel line?" I'm sure someone will chime in...
Old 02-24-2015, 06:18 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
crazy how these things just keep running.like crap with low power lol,but they just keep working.bad thing is,we don't feel the loss of power because it happens so slowly over the years.this is why every 100k it's advised to swap 'em out,to keep the engine running like new.
Originally Posted by Marianna2003
http://www.mcmaster.com/#50385k83/= Viton Seal for 5/16 Tube
http://www.mcmaster.com/#50385k84/= Viton Seal for 3/8 Tube
These are what you need.
Originally Posted by PLC7.3
Just about every diesel repair shop would stock them........
https://www.ford-trucks.com/forums/1...ion-seals.html
Old 02-24-2015, 11:43 PM
jmuenchow's Avatar
jmuenchow
I ordered both of them. Thanks a lot!!
Old 03-02-2015, 04:34 PM
jmuenchow's Avatar
jmuenchow
Is there a trick to getting the old gasket/o ring thingies out I'm having a tough time
Old 03-02-2015, 07:09 PM
ironworker40's Avatar
ironworker40
ironworker40 is offline
I heated them a little and used a pick. When installing i put them on the line then push line into fitting then push seal into fitting then push brass nut on and ntighten. I have seen people try and stuff them into brass nut first and it didnt work so well
Old 03-02-2015, 10:57 PM
jmuenchow's Avatar
jmuenchow
Thanks I was able to get it and now I am no longer leaking fuel
IrishSpike
10-03-2016 02:42 PM
eightball8
12-08-2015 11:44 PM
chewyjackson
04-04-2007 12:00 AM
Bigredcrew
11-09-2006 10:20 PM
chipper
10-20-2006 02:03 PM
Quick Reply: New IP & Injectors!! + Fuel Leak
