door lock won't work with key
I have an issue in the passenger door lock on my 2000 F250. My key rarely works on the passenger door. If it does work it takes a lot of wiggling and trying.
I have power locks that work normally and the key works great on the driver's door. I have no idea how it works but ive heard there is an anti-theft feature where if you hit the lock button twice on the fob the door locks no longer work with the key until they are unlocked with the fob again. I figured my lock issue was related to that.
Anyone familiar with this system and how to work on it? Any other ideas on what might cause this? Thanks!
My 2000 has the same problem, the simple reason it just doesn't get used often enough. With remote keyless entry I probably haven't had a key in the door lock 20 times since it was new. When I do need to use the key the locks are usually stuck. Lube it up with some lubricant made for locks and get it working again, and then try to operate it more often. The lock cylinder on my tailgate is completely stuck, I have had it out and tried to get it working again but it refuses to budge. There is no anti theft feature with these locks, it's just a simple mechanical lock cylinder.
Aus56
06-28-2014 06:35 AM
wildstang
10-21-2008 04:58 AM
