Power door locks
Old Dec 12, 2007 | 03:30 PM
1ripcord's Avatar
1ripcord
Red face Power door locks
Any ideas on how to fix the driver's door lock? The lock/unlock feature is sporatic with key fob, exterior key pad, and interior door lock/unlock button. Works fine with key and all other doors lock/unlock correctly.
Old Dec 12, 2007 | 03:59 PM
mohrds's Avatar
mohrds
Most likely the acuator is going bad. I've had to replace one after the same symptoms became worse. It wouldn't lock at all and only open about once every 10 times.
Luckily, the actuator is a really easy swap.
Doug
Old Dec 13, 2007 | 12:42 AM
Fleetsuper's Avatar
Fleetsuper
Just do a search in the threads and you will find very detailed info on a repair, and to replace the bad units with new. Even has part numbers and the like.
Old Dec 13, 2007 | 12:44 AM
i eat hybrids's Avatar
i eat hybrids
On mine, when i press the unlock button on the remote, it doesnt lock the drivers door. That only happens somtimes
Old Dec 13, 2007 | 01:31 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Yah it sound like a bad actuator but thats real easy to fix
Nick
