What power inverter to use?
I should mention that inrush (startup) current on a motor can be huge, as in 3-4 times the nameplate rating of the motor. Compressors are notorious for this as their motors start under full load. It's a frequent discussion on the woodworking forums I frequent. It may be that your circuit breaker has a quicker trip rating than a typical service panel breaker in residential use. In other words, the farther over the breaker amp rating you go, the quicker it trips. If that time delay isn't enough for the motor to get back down to running amps, it will trip.
Jason
Jason
Typically called "unloader valves" which are great in so many applications---used on all sizes of heavy duty and and use industrial-type compressors.
I know The OP really wants to power his Mak compressor, but this is another option for onboard air.
What do you need the air for?
The Makita is not a huge CFM unit, that 12volt one actually may outperform it(depending on tank used, maybe?)
I assume that you are aware of the milwaukee m12 ratchets and m18 FUEL 1/2 impact?
That 12voltair is nearly $1000. If you don't need the cfm that unit puts out, a Puma 12v compressor is less than a third of the price, 100% duty cycle and 30 amp draw. But that money could just go towards a large inverter and be done with it. A second battery mounted close to the inverter will probably yield best results.
When it comes to on-board air there are a lot of choices, among the best is ViAir. Used in a lot of applications their current demand is smaller but so is max pressure and CFM's. Using a holding tank that could be charged while driving from job-to-job would be one approach----the smaller capacity units could be used.
If immediate air is required frequently dual ViAir compressors could be used, relying on an inverter for power while the work van is at rest.
Just another idea.............
995.4SD
10-02-2013 09:58 PM
nuthinbutfords
Modular V10 (6.8l)
07-21-2010 09:13 PM
