In my 2011 SD, I have the AC outlet on the back of the console, and it appears to be rated at 120 v/40 watts. I attempted to use a small Craftsman air compressor off of it this weekend and the compressor didn't sound full power, and kept shutting off.
I am assuming the outlet wasn't fully capable of the load. What is the load rating on it? The compressor is 120 v, 3.3 amps (no wattage rating on it). It is a Craftsman 28-75117 if that helps determine what is going on.
Also, what size would work off that outlet for problems on the road again?
At 120V and 3.3A you were drawing 396 watts from the inverter. (Watts = Amps x Volts) Sounds like you'll need a inverter than can handle that load or a high quality 12V compressor. I've had my 12V compressor (one that is capable of actually airing up truck tires without taking all day) blow the fuses on my 12V outlets. I was considering removing the outlet and installing clips so I can hook it up to the battery directly.
Looking around online, there are a lot of portable inverters that can handle the load, some up to as much as 3000 watts. Why would Ford put such a low wattage unit in a vehicle like that? Better question is can it be upgraded, or should I just get one of the portable units?
That thing's for charging a notebook or possibly an electric shaver.
40 Watts seems very low though. My laptop takes at least 90 watts. I think about the only thing it would be capable of running would be things such as shavers and cell phone chargers. The built in inverter on my wife's T&C is capable of 150 watts, still won't run a compressor, but at least it can handle a good size laptop and other various items. Sounds like Ford dropped the ball on that feature.
