Quarter sized leak
Old Feb 24, 2015 | 07:58 AM
smoovmusic's Avatar
smoovmusic
Quarter sized leak
Hello everyone,
I own a 2000 Ford Econoline and I noticed while the van was parked in my garage that I have a quarter sized coolant leak underneath the van more towards the drivers side near the front of the van.
I will be looking into this further tonight. The radiator is new. Any thoughts as to what I should be looking for/at?
Also, does anyone know where I can find a diaphragm of this van (2000 ford e-250 V8) from underneath so I can use that to see what/where it is leaking?
Thank you in advance for your assistance.
Old Feb 24, 2015 | 02:46 PM
vettex2's Avatar
vettex2
I use a pressure tester
if you don't have one , borrow one
it is a pump to pressurize the system
auto parts store sometime have them as loaners
Old Feb 25, 2015 | 06:25 AM
JWA's Avatar
JWA
The pressure testing idea is a good one---might find it very quickly.
If the van can be safely started and keep running inside the garage--overhead door fully opened---get it to operating temperature then crawl underneath looking for the leak upward from the spot its left on the floor
Open the hood and look for obvious signs of an active leak all along the engine cooling loop including the reservoir and its hoses leading into the radiator.
With that size spot its not a serious leak, perhaps a loose clamp or such. These types leaks tend to leave a trail from their points of origin making them somewhat easy to find.
Old Feb 25, 2015 | 11:48 AM
Skip1970's Avatar
Skip1970
i used a pressure tester and found a coolant leak i the radiator of a escort that would only leak when really warm. worked great.
Old Feb 25, 2015 | 09:52 PM
tabijan's Avatar
tabijan
Could be a poor upper hose attachment or in my case the upper tank was separating from the core and that's where gravity directed the leak.
Sixto
93 E150 Chateau 5.8 190K miles
oneowner83
21
Apr 24, 2013 06:59 PM
B-52
6.4L Power Stroke Diesel
Sep 22, 2008 06:42 PM
jamorg2
Aerostar
Feb 26, 2004 04:50 PM
sepoirot
Aerostar
Oct 31, 2003 11:58 AM
MWL50
Sep 30, 2002 02:20 PM
