here's my delimma
here's my delimma
Had been driving 94 350 4x4 IDI Turbo until Sept 13 2014 when a caddy decided to play chicken & make a left turn in front of me. Don't know if I've ever been that po'ed in my life. This was my work truck, service body, double overload leaf, up-sized to 265/75 tire for a little bigger footprint w/ same rollout as stock 235/85, compressor, welder & more tools than most people have in their shop, scaled in at 13000 to 15000 depending on parts & supplies onboard, even hook a trailer w/ skidsteer behind it some days. Had been shopping, but not real serious, for crewcab-kids go w/ me sometimes (single dad & they love grease, 11 yr old daughter knows where more zerts are than the operators do). Knew pump 1 1/2 yrs ago, ford HD reman trans last Jan, at 6:30 am I decided finally for sure to go ahead & do bodywork this winter & drive her another 270000. At 10:30 am my mind got changed as I was driving over the hood of forementioned caddy. Twisted frame pretty good, opened rear eye on left frt spring, pushed diff up & back into oil filter & crossover pipe, cracked transfer & trans case. Had kids w/ me, thank God they didn't get a scratch. When I got home I put a new filter on it addes the 1/2 gal it had dumped out & ran it, engine all good. Here's the dilemma, bought a 77 350 2wd w/ dump bed, 61000 miles. After a little research I found this truck is original 1 owner (company) a neighbor worked for this company & remembers when they bought it, I'm assuming it's #'s matching, needs some sheet metal, but pretty solid, thought about putting 7.3 in it but not sure now that I know it's history, anybody got an opinion on this
The rear sump oil pan wants to be in the same place as the steering on a 79 and older 2wd, I had to mount my engine higher than I wanted and it still is closer than I'd like.
Numbers matching doesn't mean anything on Fords, that is a GM term involving a car serial number on the engine. Ford didn't do that, so while it may be all original it's not numbers matching.
I was the second or third owner of my truck, which started as a 69 F250 Camper Special with a six cylinder, automatic, manual drum brakes and manual steering. It was delivered as a cab and chassis but at some point got a bed put on that was painted to match. It now has power disc brakes, power steering, a 7.3 and a ZF five speed, along with heavier rear springs and a gooseneck hitch. Building an old truck is about making it yours, unless you want to do a concours build.
Even custom shops don't usually buy then build vehicles to sell, most of their work is owners wanting to get stuff done to their cars, unless is a specific car they know for sure it will sell. Good luck!
An old dentside doesnt have any "collector" value. Unless it was a twister, or snow fighter or something cool like that. SWB half ton 4x4 are worth good money, as is a highboy in good working shape.
Imo i would find a 79 F350 4x4, convert to dually and add 7.3 / ZF (hey its what i did, minus the dually) Cheers.
Thanks for the input, as i was working in the shop at the farm today & wondering how i was going get all the projects done that are already in front of me i decided to leave it OEM, just for the simple fact i'd like to put some miles on it before i'm in the ground, if i change my mind later we've got 2 more IDI engines or maybe i'll get real crazy some day & stick a 414 or something like that in it, so anyway everything from 94 is available, i will stand behind the frt axle as far as it having any damage from the wreck, does not appear to, i think the fact that the spring bushing were so wore it popped the rear eye open pretty easily & that absorbed most of the impact, i have ran the engine since and it is OK
Ford_Six
104
06-05-2017 04:55 PM
+massacre+
03-19-2006 12:50 PM
Riderman
12-01-2003 02:54 PM
Cyque
09-10-2003 12:07 AM
