'60 F-100 Leaning
Old 02-10-2015, 11:34 PM
bills86f150's Avatar
bills86f150
bills86f150 is offline
'60 F-100 Leaning
My 1960 F-100 has a 1 1/2" - 2" lean towards the passenger side. I replaced both rear shocks since the bushings were long gone and the gas charge was also history. The front passenger shock doesn't seem to have more "bounce" than the drivers side front. Would this cause the truck to lean to one side?
Old 02-11-2015, 12:15 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Probably leaf springs. Shocks mainly keep the tires on the road over bumps.
Old 02-11-2015, 11:26 AM
Maltman's Avatar
Maltman
Maltman is offline
I would check leaf springs for cracks, also mounts and bushings-I would think it would be pretty obvious since it is such a drop. Maybe spring pack worn out? Are you missing any springs and are spring equal number side to side?
I have a 3/8" lean on front drivers side-may just add another leaf
keep us posted on what you find.
Joe
Old 02-11-2015, 02:04 PM
bills86f150
It has the same amount of springs on both sides. 6 in front and 7 in the back. I measured the compressed shock length in the front and both sides are the same
Old 02-11-2015, 03:38 PM
Maltman's Avatar
Maltman
Maltman is offline
what aboot measurement from spring pad to frame? if that is good I would guess the body is to blame...mounts?
just guessing here..
Old 02-11-2015, 04:00 PM
bills86f150
I talked to the previous owner and he had replaced the springs on the drivers side but not the passenger side. He gave me a set to install so will see if that makes a radiance
Old 02-14-2015, 10:06 PM
cyclone-429's Avatar
cyclone-429
cyclone-429 is offline
Sounds like what we used to do to our circle track cars... just on the wrong side!
Old 02-15-2015, 01:18 PM
bills86f150
I don't know if I need to start a new thread but is there an adjustment to take the slack out of the clutch pedal?
Old 02-15-2015, 01:30 PM
spurredon's Avatar
spurredon
spurredon is offline
It wouldn't hurt to start a new thread, help with the search in the futur. However, there is a push rod adjustment that should make your life better. Do you have a shop manual? Once you have one you will not want to be without it! http://www.ebay.com/itm/FORD-1960-F100-F250-F350-Pick-Up-Heavy-Duty-Truck-Shop-Manual-60-/230942150479?hash=item35c5398f4f&vxp=mtr
This little beauty is als worth it's weight in gold! http://www.ebay.com/itm/1957-1963-FORD-TRUCK-COMPLETE-MASTER-PARTS-CATALOG-MANUAL-CD-ROM-wPART-NUMBERS-/200808072038?hash=item2ec1180366&vxp=mtr
Mill2580
04-22-2016 08:19 AM
brider
06-23-2005 10:09 PM
fordman311
1997 - 2003 F150
19
03-28-2005 09:57 PM
dagray3
03-11-2005 01:42 AM
Quick Reply: '60 F-100 Leaning
