93 E350 club wagon Inop Overdrive and Turn Signals only
Hi, read alot of post before I jumped in, 93 e350 club wagon 168971 miles, 3 days ago stopped and parked, When returning to leave found no turn signals, no overdrive. Everything else works, hazzards, brakes, windshield washers, all lights, no blown fuses, even just replaced them.There is no tilt steering on this van, Maybe in column bad wire? or grounded or bad o2 sensor i read? Id like to narrow my search, any help thanks..robby
The OD switch on the stalk has embedded LED's for illumination which might have failed however that would be very rare. I'd pull the steering column shrouds and check the wiring of the OD switch back to the larger wiring harness. Those have been known to chafe and short circuit.
Otherwise Mark's suggestion about the Multi-Function switch is very spot on. This should be a how-to article in the tech folder here: https://www.ford-trucks.com/forums/1...l#post11680007
This is going to sound out of left field, but how about the clockspring? I mention this from a Dodge perspective; I had an 03 Intrepid that the clockspring failed on. It also killed the turn signals, some somewhat similar symptoms although it was the horn that was also hosed, not the OD light. Again, I don't have a Ford perspective, hopefully someone will read this and confirm/deny that as a suspect. It's just a shotgun thought triggered from past experience.
