I've been to several shops and no one seems to have an answer. My truck is having transmission issues. Sometimes it shifts fine, sometimes it doesn't feel like it wants to get out of first gear. On the occasion the overdrive light will flash which mean "limp" mode. Turn the truck off and it goes away. I don't have a check engine light or is the problem consistent. Any ideas of what to check or what the problem is would be very appreciated.
Can any shop i go to read that? I don't have a scanner and without driving to the ford dealer that's 45 min away, that's my only option.
Most any shop should be able to do it if it's not diesel. Should be an OBD II port. Even an Auto Zone can generally pull codes for you. But the diesels usually need more specialized software and many places don't have it if they don't work on diesels.
Turns out i was driving to work the other day and the transmission went up completely. Thanks for the help guys. I will come here when i have any more questions
