1960 Transmission Floor Shifter Boot
There is no Ford truck parts catalog listing for a T-98 shift lever boot for any 1957/64 truck.
What these truck came with originally was this: C0TB-8112130-A .. Transmission Cover Weather Seal ~ 2" 1.D. x 7.00" O.D. x 2.00" thick / Obsolete
This was located between the transmission cover plate and floor pan to prevent water, dust and etc. from entering the cab.
It's obsolete, no one has any NOS and AFAIK, it isn't reproduced.
I used thin waterproof foam, built into layers, to create the seal between the top of the trans and the bottom of the trans hump on my truck restoration. It actually was the foam you use between a foundation and the first layer of wood in house construction. each layer was glued together with 3M weatherstrip adhesive. Seals out the elements great.
Nick in WI
Nick in WI
not too familiar with the floor shifter boot you are after, but I saw this the other day and thought this is what they look like...
Mr. Gasket 1651 - Shifter Boot | O'Reilly Auto Parts
Here is a pic of the trans water seal that was in my 63 F250 4x4 with a T98 trans. It has a round metal retainer that It sits on between the trans cover and the trans. I used it in my 65 it seems like it is made from dense cell foam rubber just made in a round design. Im sure you should be able to duplicate it.The plate sits on top of the trans then the foam block. It is in the middle of the picture.
Devinnn
09-10-2012 08:08 PM
Shelbyf150
07-22-2008 12:22 AM
