3 Speed Help!
Old Sep 9, 2012 | 10:01 PM
Devinnn's Avatar
Devinnn
3 Speed Help!
Hi my name is Devin
I recently picked up a running 78 f100 longbed with a 6 banger in it and it has the whole 3 on the tree. I am new into trucks and want to know how i could make it a floor shifter?? Any help would be great.
I'm new to this fourm so if this should be somewhere else just tell me
Old Sep 10, 2012 | 07:45 AM
stuart1's Avatar
stuart1
Get a floor shift kit from an aftermarket parts supplier and follow the bouncing ball.
Instructions are included and be neat about it. You will have to cut a piece out of the floor boards.
Not really a difficult task.
Old Sep 10, 2012 | 02:17 PM
xlt4wd90's Avatar
xlt4wd90
Just measure where the shifter will go through the floor carefully (3 times) before you start cutting.
Old Sep 10, 2012 | 03:15 PM
85e150's Avatar
85e150
Originally Posted by Devinnn
Hi my name is Devin
Greetings and welcome to FTE.
IMO, run it as-is for a while. That is, IF the shifter works OK. I like a floor shifter too, but there are few advantages here vs. a good working column shifter. After you run it a few miles, see how the gearing is. Too high, too low, big gaps between gears? Or is it just right?
If you like it, research the floor shifter and cut that hole in the floor.
If you don't like it, research a later model 5 speed OD trans. If you are going to go through a bunch of work, might as well get as much as you can out of it.
Old Sep 10, 2012 | 08:08 PM
Devinnn's Avatar
Devinnn
Thanks and yea i was going to wait a bit to see if i start liking the colum shift more, but I wanted to to a 5 speed swap anyways so thats a good idea!
whitre
2009 - 2014 F150
Jan 21, 2008 10:17 PM
BIIman
Nov 21, 2006 12:43 PM
custom_truker
Sep 25, 2003 05:51 PM
deronyv8
Oct 13, 2002 05:42 PM
