Thinking of buying a 2003 F150
I bought a 2001 with 125K on it and drove it till it had 250K.... Last summer I got a 2002 with 100K and started over with it.......... 138K is below average mileage if it was taken care of...
Ask if it has had spark plugs.
Ask if the trans oil has been changed
Ask if the front wheel bearings/ hubs are original or new
Ask when it had brakes installed
Look in radiator for signs of sealer or addatives in the antifreeze
As a general rule, Probably wouldn't look as vibrant, but a bit dull in color, & or, perhaps some residue floating on the top of the coolant. "The floaters" would be better/ easier seen if one has a direct view into the radiator prior to it being started and run up to temp, things get remixed after the coolant gets circulated and not as easy to see. But many radiators do not have that "direct view" via a radiator cap today, aka old school. So that leaves you to check the interior side walls of the overflow tank, or purge tank, or degas bottle, or what ever they want to call it these days. If its interior side wall looks dark, slimy & residue laden, then odds are good some kind of sealer/ additive was added some where in its past. But ...These semi-clear overflow tanks do tend to get a little dirty or stained over the coarse of time, as coolant systems tend to be very neglected. So don't expect to see a very clean interior either.
Thanks for all that feedback! I think I did great, found a 2003 F150 with 113k on it for $7300-7400, I've checked as much as I could have. It's the FX4 four door super screw. I think they are half ton trucks if I'm correct.
Anyways the coolant smelled good, looked good nothing floating in any of the tanks and no engine stuff noises.
In terms of ball joints and such; ball joints were replaced; tie rods, new brakes, rotors, wheel bearings front. They are freshly new you can see it and got the paperwork a on that stuff being done.
I don't know if its just the new brakes or new bearings; I ran it twice and there was no noise. Then bringing it home it snowed and was pretty went on the roads. Half way the back wheels are squeecky half turn every turn or rotation of the wheel. Not real sure about that will see today.
I'll open a new threat and get some photos of the truck and do a whole intro. Thanks again guys.
Yeah love the look of it. Two color paint, larger wheels it looks.. a few issues of course like a straight pipe (no muff) that might need to change; sounds awesome but just might need a muff for next year inspection. Also the door locks, they unlock without an issue but locking them no go.. I'm thinking relay.
Ok, so after looking at about 5.... and hoping to find a 4 door FX4 in 2003 year.. finally found one and pulled the trigger on it. Here she is... the dealer stock photo for now; too much snow in my area to wash and take real good photos for the whole introductions, but I will.
What do you guys think? it's 2003, FX4.... with 116K. Has a little brake squeaking going on from time to time, something I'm gonna have to figure out or take it back and let them either adjust the e-brake if its dragging or I donno. Also either alternator/belt or pulley is making weird noise when cold but that's for summer I guess.. or little warmer temps.
Dealer photo
Dealer photo
Dealer photo
Dealer photo
Is the "weird noise" just on start up?? and quickly goes away with in a few seconds? or is it prolonged until engine is warmed up?
If it is just shows up on severe cold weather and cold starts & last just a few seconds, it's prolly the power steering pump trying to move thickened power steering fluid. You can try using the turkey baster to suck out as much PS fluid as possible and refill it with new...start it & let it circulate a bit and drain it again and refill and restart. Do that a couple more time and you should have most of that old stuff out it might help with the noise.
If it is lasting for a longer period then it could be number of different things
Look'n good
El Camino Man
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
12-31-2016 04:55 AM
