Air bag light code
Air bag light code
Getting what I assume is a 32 code. Light flashes 3 times then pauses and flashes 2 times then repeats. I see code 32 says: DRIVER SIDE AIR BAG CIRCUIT HIGH RESISTANCE OR OPEN (CODE 32)
What do I have to do to correct this. I primarily just want the light to go away, but I think I read that if you just remove the bulb it will result in warning beeps?
Thanks for the info. I know sometimes the horn and cruise will not work when clock spring is bad, but mine both work fine. What type of diagnostic procedure would indicate that is definitely the clock spring?
Edit: is it possible to remove the bulb and also deactivate whatever makes the beeping?
Pulling the bulb will make the module beep. Unplugging the diagnostic module (blue box under the dash) will make it STFU.
Note that it's against the law to disable your airbags
